The lid on my toilet seat slammed down one time too many (I found this site by searching for the answer to that problem, which I had kluged by putting a bungee cord around the tank to hold the lid up while cleaning the bowl) and sheared off the pin around which the seat and lid and bolt extensions rotate. It's a piece of opaque plastic (acrylic?) and probably costs about a dollar, so I don't want to buy a whole new seat & lid combo just to replace that piece.
I intend to use the brilliant solution I found on this site (rotating the hinges 180 degrees) to keep this from happening again, but in the meantime I'd rather not send the seat & lid combo to the landfill for lack of a tiny piece of plastic. Any suggestions welcome.
To clarify for the helpful souls who responded so far: I do not want to replace the hinges if I can repair them. I'm not sure what the stainless steel bolt and nut refer to. The piece whose name (and buying site!) I am looking for is a small cylinder of plastic/acrylic/manmade whatever. There are no bolts or washers or parts that stick out. Just a smooth cylinder. Sorry that I wasn't clearer :-(
    Stainless steel bolt and lock nut. ?
    – Alaska Man
    May 25, 2019 at 17:14
    Go with the stainless nut and bolt.. easily available, simple to fit and cheap...
    – Solar Mike
    May 25, 2019 at 17:25
    They do make seats that do not slam shut , Have two myself work great. You may be able to buy the hinges..Or you can get bolt but that does not stop the slamming.
    – user101687
    May 25, 2019 at 21:01
Personally, I'm going to the hardware store for nylon spacer. I will need the length of the pin and the outside diameter.
  • As it’s currently written, your answer is unclear. Please edit to add additional details that will help others understand how this addresses the question asked. You can find more information on how to write good answers in the help center.
    – Community Bot
    Nov 11, 2023 at 12:34
