I built a shed last year on sloped ground, using concrete piers. I didn't get around to adding gutters, and was contemplating not doing it. But, the water seems to be eroding some areas of the soil around the shed (which I recently added mulch over), and leaving a faded line on the top step, as well as a faded line on the fresh mulch.
In the picture below, I am looking to add some flowers/medium sized plants on the right side of the steps. Is there any harm in adding the downspout at the high end of the slope so the water will run out in this area and give more water to the plants? And also, let the water disperse through the soil more at the high end, rather than two spouts pouring out at the low end. I was thinking putting the rear spout at the left side, and the front at the right. Or is it better to direct the water entirely away from the shed and put the down spouts on the left side? Looking for advice and another perspective on this in case I am missing something, or if the water running down from the high end would cause any issue down the line.
I do have a french drain in the center of the yard as well, which helps dissipate any middle standing water.
