I installed a new ceiling fan that has a remote switch box. Everything worked fine. I couldn’t tell what colors the wires were in the ceiling, but followed the wiring that was already there. Now, the only thing that works in the circuit is the fan. I just found out another switch controls the fan now on its own, but not the light it’s supposed to... Why would the circuit change with the added remote fan and how can I fix it?
reference: sw1 and sw2 are connected to the fan, sw3 is an exterior light wired in the same box as sw2, sw4 and sw5 are in two other rooms.
Troubleshooting:
  • Only the fan works; the other three lights do not work.
  • all sw off (fan off) - 1 white pwr, 2 no pwr, 3 top black pwr
  • Sw2 on (fan off) - same as all off
  • Sw1 on (fan off) - 1 w/b pwr, 2 travel black pwr, 3 top black pwr
  • Sw1 on/sw2 on (fan on)- 1 w/b/r pwr, 2 tb/b/r pwr, 3 b/b pwr
  • Sw1 on/sw3 on (fan on) - Same as 1/2 on
  • Sw3 on (fan on) - same as 1/2 and 1/3
Fan box enter image description hereenter image description here Fan remote assembly instructions enter image description here Sw5 light enter image description here
    Can you show us how the other light boxes involved are wired? – ThreePhaseEel May 23 '19 at 22:35
  • The diagram is helpful, but pictures would help too. – manassehkatz-Moving 2 Codidact May 23 '19 at 22:47
  • Sw 4 runs another fan but only has one white and one black wire running to the fan – user101972 May 23 '19 at 22:53
  • On the 3-way switches SW1 and SW2 -- which wires are on the black screws also labeled "common"? – Harper - Reinstate Monica May 23 '19 at 23:02
  • Both black screws have black wires – user101972 May 23 '19 at 23:03
