I posted previously in regards to an exterior window trim issue I discovered, where the previous home owner did not put any waterproofing around the window.
I have since waterproofed around the windows using foam and silicone. However, the silicone is exposed and I would like to cover it with trim again (now that it is properly? sealed).
Is there anything I should keep in mind prior to putting on trim again? I was just going to brad nail it on, and maybe silicone between the trim and window.
--- UPDATE ---
So I decided to just not use trim. I stuffed backing rod in the gaps around the window, and siliconed the heck out of everything. These windows are now completely water tight. I am now going to put the highest quality paintable caulk I can find on the silicone then paint. As mentioned, the trim really only makes the problem worse by catching water and such. Thanks everyone for all the helpful comments and critiques!
