I am running approx 40' of cable thru the unfinished attic in order to install two additional receptacles in the kitchen. The easiest and least obtrusive way for me to do this is to attach 1x3 or 2x4 lumber to face of the rafters to serve as a raceway, then staple the cable every 4 feet or so onto the surface of this raceway. The wood strips will be attached to the rafters approx. 4' up from where the rafter tails meet the floor. At the end of the run, the cable will drop into the kitchen wall.
Does this installation meet current NEC code, or is there something else I need to do to make this meet code? Tks.
marked as duplicate by ratchet freak, Daniel Griscom, ThreePhaseEel electrical May 21 at 23:05
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
    I'd be asking if you can just staple to the underside of the rafters. I'm not sure why a raceway would be necessary. – isherwood May 21 at 15:40
  • Wiring cannot hang unsupported between rafters to avoid snagging or other accidental damage. This question pertains specifically to attaching to rafters, not joists. – Gary G May 21 at 17:56
