I have an old and damage sidewalk with a heater wire inside it.
The wire is cut somewhere but I don't know how to find where. Is there any electrical tool or way to find where is it cut?
This is an example of a wire in a sidewalk:
Heater wire in a sidewalk
  • I would start with where the most recent work took place... – Solar Mike May 21 '19 at 14:33
  • does it heat some of the sidewalk, or nothing at all? – dandavis May 21 '19 at 17:59
Yes there are scanners that can read through concrete and even metal conduit, but they are expensive the one I use is a greenlee CS-8000, I just did a quick search and new these are ~750$. You may be able to find a used one for much less, these are awesome for finding a broken wire even in rigid metal conduit, through walls, identifying circuit breakers even if the power is off. There may be other brands/models out there but mine has saved me hundreds of hours and I have found faults that 2 electricians before me could not find , the difference was I have this simple but high accuracy tool.
| improve this answer | |
    If it is likely to be a one-time use then worth looking for a rental. – manassehkatz-Moving 2 Codidact May 21 '19 at 14:35
    I’ve not seen them as rentals but fully agree. I did some more looking and found a new one on line Gordon electric 444.00 and a used one e bay 400$ – Ed Beal May 21 '19 at 14:43
A non-contact voltage detector may be able to help you if you remember or have pictures of the cable from before the pour.
I have no idea how you think you're going to repair it if you find it though, cutting the concrete open will also cut the cable again.
