I’m an electrician by trade but i have a friend who needed his blower motor replaced. The parts store sold him a motor but it only has one hot leg. The control board has a hot for cooling and a hot for heating. What would happen if I wired them both together to the hot for the motor? I’m afraid back feeding the control board might fry it? Any suggestions would be appreciated.
    How was the old blower motor connected? – manassehkatz-Moving 2 Codidact May 20 '19 at 18:01
  • Had a hot for cooling and heating. It’s an old unit. – user101844 May 20 '19 at 19:09
  • The original may have had different speeds for heating and cooling. Running at a single speed may result in other problems, e.g. icing the evaporator. – HABO Feb 10 at 20:31
It'd be fine, simply because I can't think of a 120 volt AC relay that would be damaged by getting back fed power. Mechanical and solid state can both handle it as far as I know. That's not a 100% you're good though, maybe 90+% confidence?
Worst case it passes current backwards through to hot and won't be able to shut itself off, but you'll catch that during testing. Nothing should blow up.
    That’s what I was thinking Ok thanks for your thoughts and your time. – user101844 May 20 '19 at 23:48
