At the bottom is the stairs is the first 3 way switch in this circuit - it doesn’t need to be messed with because it was never changed and works good.
Then go up the stairs a little where a 4 way switch needs to be wired.
The wires I have on that one to hook up are 2 white, 2 red and the blacks inside are wired nutted together.
Then in between this switch is the 1st light with power source which goes to another light, then it stops at the last final 3 way switch.
So how, do I wire my 4 way?
I could get pictures if you need. Btw we originally replaced it and must of wired it wrong because when one switch is off another won’t turn light on!enter image description hereenter image description here
    Punctuation is your friend. Don't be afraid to use it. – brhans May 17 at 22:23
    I am willing to help, but I can't make any sense of this. Meet me halfway and edit your question so it is clearly stated and understandable. – Harper May 17 at 22:26
  • Done all fixed punctuated and makes sense – Colincook May 18 at 0:27
    Can you post pictures please? – ThreePhaseEel May 18 at 0:42
  • much better :) +1 – Harper May 18 at 15:09
  • Unhook all 4 conductors.
  • Identify 2 conductors that are in the same cable. Necessarily, one will be white and the other red. This pair will be a pair of travelers.
  • While we're here, it's illegal to use a white wire this way without marking it with black or a color. Also, nothing tells you that this white is associated with that red. I suggest marking both the red wire and the white wire with electrical tape of the same color, e.g. yellow. You can mark them the same color because both wires do the same thing and are interchangeable.
  • Anyway, these two travelers go on the Brass terminals of the switch.
  • One pair of travelers will remain, also white and red.
  • Same thing, mark them so the white is tagged a color and also to associate them with each other.
  • This set of travelers goes on the Black terminals.
How did I know? I just know how 3-way/4-way circuits work.
    Thx it worked well how did you know how – Colincook May 19 at 15:31
  • What is the function of the 4 way switch. It seems to be a double pole single throw switch, which is basically an on-off switch. Why use DPST rather than another 3 way? – Yehuda_NYC May 20 at 15:45
