I want to replace a door knob, but I have 2 problems:
- After removing the door knob, I can't remove the latch assembly from the edge bore. Is there a mechanism to remove this from the door, or is it simply a matter of brute force?
- The latch plate is different from the new one. Is it a matter of chiseling the side of the door to fit the plate, or do I need a completely different product?
