I need to hang a swing (picture attached) from a large wood beam in my living room. The beam is 1 foot high and 1/2 foot wide. (quite strong).
I am planning to use 2 metal faceplates . Each faceplate has a hook welded to it and has 3 holes. The holes are 1/2 inch in diameter.
The swing seating area is a flat plank.
Need to support up to 1000 lbs total.
Q: Can I drill a lag screw / nut vertically to hang the swing ? (picture) Q: If so, what are the recommended lag screw dimensions: 1/2 inch diameter x 6 inches long or 1/2 inch diameter x 4 inches long ?
Q: alternatively, can I use a 1.2 inch diameter - sleeve anchor ? or is this only for concrete?
