My condo building has AC ports (essentially a round hole that goes outside) in every unit, to which you can connect an air conditioner. However my unit doesn't get too warm so I want to use the AC port to bring in fresh air from the outside instead, possibly warming it up first during winter months.
Is there a fan/heater combination I can use for this purpose? Or perhaps regular portable air conditioners can work in this mode?
  • a small space heater would seem to fit your bill, especially one with a fan mode.
    – dandavis
    May 16, 2019 at 19:21
I assume you can just stick any appropriately-sized fan in front of the hole. For heating purposes, an air exchanger is designed to recover heat/cool from interior air before exhausting it to the outside, but it's annoyingly expensive for what it is. You can get air conditioners that have heating as well, (a heat pump is just an AC run in reverse) but it requires a bit of extra mechanics, so you won't find this feature on the cheapest ACs. You can look for, say, "Air Conditioner With Heat Pump", or "Air Conditioner With Heat", and get a good selection at the few hundred dollar range.
Efficiency of a heat pump is above resistive heat, but still not great, especially for a portable unit. You should absolutely insulate the hose if you plan to use this long-term.
