I am replacing carpet with LVP in my bedroom, the LVP is going to flow into the hallway (no transition), I need to raise my wood floor 1/2" in the bedroom to match the height of the hallway, can I use OSB or should I use Plywood?
  • I’d use OSB, if you can insure no moisture. – Lee Sam May 14 '19 at 19:01
  • No moisture issues. I am planning on screwing the flooring down too. Thanks Lee! – Dave Matthews May 14 '19 at 19:23
