Trying to install vertical blinds for 2 slider doors and I cannot locate any stud/plywood backing in the areas I need to drill the holes for the mounting brackets.
- Have any of you used pop toggle anchors in this situation and has it lasted?
- I have 4 brackets only included in the package, would that be sufficient to hold the vinyl blinds (around 96 inches wide, 80 inches tall
What other options do I realistically have? Not trying to open up the walls if it can be avoided.
