I made a decision that is giving me several problems: I decided to put a microcement floor in my house.
One of the dirtiest problems is in the shower. The micro-cement around the drain gets wet when I have a shower.
As you can see in the image, I tried to put some SikaFlex in between the drain and the floor, but it doesn't work.
Do you have any clue about what should I do?
