Crappy cabinets, shelves made of MDF. The contractor will be installing tile backsplash next week. I thought it would be the right time to fix the shelves, too.
The question is about the bottom shelves. I am less worried about internal shelves - these can be braced easily.
Edit: Upon doing some research, I came across this product. Google "shelf stiffener". I have not tried it but it looks promising.
4 Answers 4
Assuming you don't want to spend the money replacing with all solid wood cabinets (which is what I did last year), you could double the shelves up and screw the old one into the new one. Use screws no thicker than the two boards combined (obviously).
saggy shelf
  • That's neat. Other than some minor issues with the screw heads showing and the solid wood boards taking up some space inside the cabinet, I think it's a viable option.
    – user443854
    May 14, 2019 at 17:45
  • A bit more expensive but possibly permanent solution, inspired by this answer: use aluminum angle. Run one along the back and one in front. The one in front can be flipped to face downwards to minimize obstructing the shelf.
    – user443854
    May 14, 2019 at 22:59
Older cupboard shelves often had a 2" by 1" or 1" by 3/4" frame under the shelf which gave so much support.
This was often decorated with a facing strip with carvings...
  • I know what you mean. I wish my cabinets had this support structure.
    – user443854
    May 14, 2019 at 17:46
Flip them. They're likely harder now than when they were new and won't sag as readily. I don't know how the cabinets are assembled, but the bottoms may be removable for flipping as well, or flip the entire cabinet.
Otherwise, you could double the bottoms. Fasten a new shelf inside with suitable screws. 1/8" to 1/4" shims at each end would draw the center up more effectively.
BTW, they're probably particle board, not MDF.
  • Doubling was the first answer above...
    – Solar Mike
    May 14, 2019 at 15:35
  • Yep, and it's part of the this answer, wiith additional suggestions. Answers often overlap.
    May 14, 2019 at 15:48
Thanks all for the discussion. This is what I ended up doing. Project cost: 60$, beer.
The shelves are 12" wide. The select board from Home Depot is 11.5", so I had to glue a piece to extend them to 12". The glue was left to dry overnight, then sanded smooth with a belt sander. The grooves in the shelves were cut with a router. The finish is Minwax wipe-on poly.
enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here
