The dryer wasn't working. I realized the timer button was broken and wasn't properly turning. I took the back cover off and when I turned it by hand it worked. As I was putting the start button back in, I bumped the timer device and it flipped back and came in contact with the metal edge and I saw it spark. I cut the wire back, replaced the connection but nothing. Now, the light doesn't even come on. Suggestions?
    You opened up the dryer without unplugging it first? – Machavity May 13 '19 at 23:56
    Did you check the breaker? – Jim Stewart May 14 '19 at 0:01
    What model is the dryer? – ThreePhaseEel May 14 '19 at 0:36
  • 1)the breaker is good. i plugged it back – doug May 14 '19 at 8:20
