I am trying to identify a mystery wall receptacle that I have in my house (built in the 60s, USA). I have one in the living room next to a fireplace, another in a bedroom. It looks somewhat like the C8 socket, but is more rectangular and rough-looking.
Does anybody know what this is?
EDIT: added opened picture
Mystery wall connector
Opened plate
  • an early phone socket? or for a speaker? – Solar Mike May 12 '19 at 18:30
    A duplicate of this question, I believe: diy.stackexchange.com/questions/29430/… – jwh20 May 12 '19 at 18:48
    As the flat wire is now exposed it is a tv antennae connection and this is a duplicate of the other question – Kris May 12 '19 at 18:52
    Thanks everyone, I think this is indeed the same socket as the other question. – Daniel S. May 12 '19 at 18:54
18
Thanks for providing the "opened" picture, which clearly reveals that this is 300 ohm TV (and/or FM radio) antenna twinlead.
Not quite as obsolete as a buggywhip, but pretty close.
| improve this answer | |
  • +1 for "twinlead". That was indeed the type of antenna lead wires. – Michael Karas May 12 '19 at 20:22
  • Are HD antennas not roof mounted, and signal over this wire? – JTP - Apologise to Monica May 13 '19 at 1:57
    The original TV antennas this stuff was common for still work with HDTV if you have them (you don't actually need a "HDTV Antenna"), but most modern antennas use a 75 ohm coaxial feed rather than twinlead. It's shielded by design, which reduces interference pickup. It's also a LOT easier to find hardware for, these days. – Ecnerwal May 13 '19 at 2:07
