I am replacing a light switch and found three black wires going to it. Two go to the screw terminals and one goes to the push terminal:
I verified with a multimeter that the central and bottom terminals are always live, and the top terminal is live if the switch is in the up/on position. Is it safe to just pigtail the bottom two wires together when replacing the switch? The new one only has one hot wire.
