I am working on an outdoor LED lighting project where I'm making my own rope lights to hold up to the elements. I am using waterproof LED strips which are surrounded in a plastic "jelly-like" material and I am enclosing them in clear, plastic tubing. This means that I intend to slide the LED strips inside the plastic tubing and it's a slow go because I'm getting plastic-on-plastic rubbing. To put this in context, the strips are 6 feet long and about 3/8" wide and I'm putting them in tubing with a 1/2" inner diameter.
So, I think I need some sort of lubricant to make sliding them in easier but I also need it to not leave a residue so that it won't interfere with the clarity of the tubing and wont affect the electronics of the LED strips. Any suggestions?
