I have this lead light mirror, how would I go about wall mounting it? It presently has no backing of any sort.enter image description here
  • Talk to a professional - if that hanging support is attached wrong, then it could cause the bits to separate...
    – Solar Mike
    May 11, 2019 at 11:53
  • If you're ok with if being a permanent fixture then lots of construction adhesive would work. Just be aware that it'll never come off again in one piece.
    – brhans
    May 11, 2019 at 12:51
  • diy.stackexchange.com/questions/110942/… (the mirror mounts, not the swiss frame clips)
    May 11, 2019 at 13:57
  • @Ecnerwal I think the swiss frame clips, or something similar, would be another option. May 11, 2019 at 14:38
For a "floating" appearance you could use construction adhesive (or "mirror adhesive") to mount a board to the back of the mirror (just the central mirrored part), and use some form of hanger or French cleat to attach that to the wall, with the mirror itself out a bit from the wall.
That would lend itself to wrapping that board with flexible light strip or rope lights to "halo" the mirror a bit and emphasize the stained glass edges by lighting behind them.
Use mirror clips, and plenty of them.
If you don't want to use hollow wall anchors, you might want to build a wooden frame as an attachment point for the clips, and then you can put them wherever the mirror needs them.
