I have a 4 bulb light fixture which suddenly just went out. I checked and there was power to it. I changed all the bulbs in case one was bad and still nothing. So I purchased a new ballast and installed that. Nothing. There is power to the ballast and power in all the wiring going to the bulbs. So I have no idea what to check for next! Any ideas?
21. How are you determining that there is power? Use a load (e.g. incandescent lamp), not a meter. 2. Are you sure the ballast is wired correctly, with the correct sockets (shorting vs. non-shorting)? – DrMoishe Pippik May 10 '19 at 0:52
Shoot us photos of how you wired the ballast. Bet the problem is there. Did you have any extra wires? – Harper - Reinstate Monica May 10 '19 at 5:08
Are the starters OK ? try to replace those. Are you using an electronic ballast or a good one? Is your neutral OK?. And also: where are you on Earth? – DDS May 10 '19 at 9:08
If the ballast is wired correctly make sure the connections to the bulbs aren't loose. You could replace a pair of connectors as a test if your fixture allows.
Hello, and welcome to Home Improvement. This is really a comment, not an answer. With a bit more rep, you will be able to post comments; please take our tour so you'll know how better to contribute here. – Daniel Griscom May 10 '19 at 11:42
