I am looking to mount an over-the-range microwave above my stove, but there is no cabinet on top. Here's a picture:enter image description here We originally planned to mount a shelf to the wall above the stove and use the shelf instead of a top cabinet for mounting the microwave. We bought a piece of 3/4" plywood and cut it to size. However, when we went to buy brackets, the guy in Lowe's said that he didn't think it would be strong enough.
My question is, would this work? Can we mount an over-the-range microwave using a 36"x12" piece of 3/4" plywood as the 'top cabinet'? Will it hold? What kind of brackets do we need for the shelf? The microwave is 65 pounds. Installation instructions are here.
There is another question on this site about this, but it is not as detailed and there doesn't seem to be a definite answer there.
3/4" plywood is plenty strong enough. The issue is the brackets. They need to be very strong and, most importantly, mounted directly into studs. I would not rely on anything less - toggle bolts, expandable anchors, etc. Screws into studs.
It may be a bit tough to find the studs - I'm not sure if a regular stud finder will work through the tile. If you're not sure, drill some pilot holes in the area that will be blocked by the microwave oven. Once you find the studs, drill pilot holes for mounting brackets. I would drill just a drop larger than the screw diameter through the tiles (so that you don't crack the tiles) and then a bit smaller (so the screw can grip the studs) into the studs. Ideally you want to go an inch into the studs, so probably 2" screws - 1" into the stud, 1/2" drywall, 1/4" tile and a little extra for the brackets.
What kind of brackets? Almost anything will do, but I would generally recommend something that:
  • Has support for at least 3/4 of the depth of the shelf
  • Is several inches tall
  • Can be screwed into the stud in at least two places per bracket
Something like this:
Depending on how your microwave oven mounts, you might want to attach the brackets upside down on top of the shelf, leaving a totally clear shelf for mounting the microwave oven underneath.
You will probably want to drill a hole (use a hole saw) through the shelf to run the power cable up to the receptacle.
The hard part will be the exhaust vent. Depending on the microwave oven and depending on your house structure (is it an outside wall? where are the studs?), you may be able to cut a hole in the wall (through the tile) for the vent. Or that may not be practical and then you would go up to the ceiling and then out (roof or to a side wall). But without an upper cabinet, any ductwork (except straight out behind the oven) will probably not look very good.
    If you mount that kind of bracket upside down, use washers and through-bolts, otherwise you're banking on the pullout strength of screws in 3/4" plywood, as opposed to the shear load a cabinet would have when hung with 3" screws....
    – Mazura
    Nov 15, 2019 at 23:52
    I don't know what the protocol is for this, but I wanted to thank you now that it's been up for a few months. The shelf was pretty easy to install with the brackets as you suggested, I stained it to match the cabinets, and we are very grateful to have our microwave. Thanks!
    – user101270
    Feb 9, 2020 at 5:27
    First, you're welcome. Feedback that an Answer actually "worked" and not just "accepted as best of the bunch" is a really nice thing. The official protocol is "Accept the answer", which you did. Officially, comments are not for this kind of "thank you". meta.stackexchange.com/questions/19756/how-do-comments-work However, that is one of the many things I feel are "broken" about SE, which is why I no longer contribute here (no new Answers, even when I think I have the "best" answer; no edits even when I see obvious mistakes). I'm helping at codidact.org to write the next best thing. Feb 9, 2020 at 5:43
There are brackets made specifically for mounting a microwave oven on the wall. When you use these there is no need for a separate shelf. Do make sure to mount the brackets into studs and not just to the wall with hollow wall anchors.
(Picture Source: https://www.amazon.com/dp/B07FPFNFB1)
The set of brackets shown above are rated for 110 pounds when securely screwed into two studs.
    Thank you! My microwave is an over-the-range one, though - it has a vent fan underneath to replace a range hood. I don't think you can put brackets underneath it because the vents have to be clear. These microwaves are usually installed by hanging them from a metal plate attached to the wall, and then screwing them into the cabinet above to stop it from tipping forward.
    – user101270
    May 5, 2019 at 23:22
I know this is an older post, but I didn't find any that solved this problem the way I did so I thought I'd share for anyone doing a search.
https://www.reddit.com/r/HomeImprovement/comments/do009o/hanging_microwave_without_cabinet_a_howto
    And again: it's best if the info is in your answer, rather than in a linked page. Nov 15, 2019 at 21:40
