Set a toilet flange before laying tile, overcompensated by almost 3/4". I cut some plywood to wedge under it, and my only thought is to run a very thick bead of caulk in the gap and hope I make it look halfway decent. Has anyone ran into this issue before, and is there anything else I can use to fill this gap and make it look good? enter image description here
    First, my condolences. It happens. If you have a good plastics supplier, I'd get a chunk of 3/4" white hdpe and trace the base perfectly. It'll still look like a hack, but it'll be functional. May 4, 2019 at 21:06
  • Are you sure the spacer is necessary ? Did you dry fit the toilet onto the flange without a wax ring to see if the toilet sets flush on the floor without rocking. ? What is the flange fastened down to that makes it sit so high ? Do you have access to the plumbing from below ? In my experience it is difficult to get a thick bead of caulk to look good.
    – Alaska Man
    May 4, 2019 at 21:34
  • Is this on a concrete slab floor?
    – Kris
    May 4, 2019 at 22:10
  • Yes it's on a slab
    – BigLake
    May 4, 2019 at 22:42
  • Was the flange a pvc glue on type on 4” pipe? Can you post some pictures of the flange?
    – Kris
    May 5, 2019 at 1:33
One solution is to trace the toilet base on a piece of 3/4 plywood and carefully cut the shape out. Place the plywood with shape removed around the flange mimicking the outline of the toilet.
When you have it placed in exact position secure the cutout to the floor with tape and fill the area with sanded grout. When dry remove plywood form, set toilet on the bed of grout.
Mix a bit more of the grout and dress the edges with this. Neatly sponge the area and you should have a decent looking durable base under the toilet that will last a long time .
Never seal around the toilet to the floor! You then sacrifice the ability to see what could become a major problem. If the wax ring goes out, you will never know and that can lead to major repairs down the line. Never seal or caulk around a toilet base ever!
Just fix the real problem, cut the flange out and replace, too low? Shim kit or tall flange kit, never double wax ring, and never seal the toilet to the floor, you are begging for disaster down the line. Just fix the actual issue, don't disguise it.
  • Just fix the REAL problem, cut the flange out and replace, too low? Shim kit or tall flange kit, never double wax ring, and never seal the toilet to the floor, you are begging for disaster down the line. Just fix the actual issue, don't disguise it Jun 28, 2021 at 15:35
So I went ahead with the grout under the toilet. I actually put the wax ring on, cut my plywood about 3/16 smaller than the base, set it, leveled it, then filled with grout. 2 days in and it looks great, gonna finish it with grout seal to brighten it up (almost matches the toilet color already). Thanks for the tips guys. I'd recommend this procedure to anyone else that runs into this issue.
