I have a water pump that fills up water tank on roof top. I have to turn on water pump manually every time the water supply is on and then have to turn it off when supply is off to prevent dry running pump.
I want a switch that can turn on/off the pump automatically sensing water supply. What that kind of automatic controller switch is called and how to use it ?
  • Sounds like the opposite of a well switch. Good question.
    May 3, 2019 at 14:31
    Sounds a lot like a float switch used for a sump pump.
    – pathfinder
    May 3, 2019 at 15:10
  • Can't use a float switch in a closed plumbing system.
    May 3, 2019 at 15:44
  • @isherwood - agree it would be difficult to get the float wires though a closed tank, but Q doesn't state that it is closed. I use a similar approach for my 300 gal irrigation water where the float enables the pressure switch for the transfer pump.
    – pathfinder
    May 3, 2019 at 18:17
Edit: I think I misread your question, your only water pressure is from gravity? I assumed your water supply was pressurized. You want something to sense the water level in the tank to cycle the pump, not pressure or flow related.
Sensing water flow is more complicated than just sensing water pressure. A SPDT water pressure switch can be installed at the water pump inlet to power the pump when it senses water pressure at the pump, and cuts power if it doesn't sense water pressure. This way the pump always runs when the water supply is on, and never runs when the water supply is off.
Ideally you'd have an electric circuit that opens a solenoid water valve for your supply and powers the pump at the same time, being activated by a water level float or sensor in your tank.
I use the same switch for my reverse osmosis water filter. I have an AquaTec SPDT pressure switch that prevents the booster pump from running if there is less than 20 psi supply water pressure. That way it never runs if there is a problem with the supply, because it would run nonstop and eventually burn out the booster. Technically it wouldn't run dry, because air would have to be introduced into the system first which would be unlikely.
