The very quick backstory is that in order to remain grandfathered to retain my current setbacks (i.e., too close to property line and alley), I must retain those 2 original walls of my garage. I intend to pour a new slab over the current one since it is too low anyway and expand it in the 2 directions I am able at the same time. Our inspector said I could lift the walls in order to do that as well as replace the sill plates, which are surprisingly solid, at the same time. To make pouring much easier, I intend to just move the walls a couple feet off the slab and move them back when new slab is ready.
My question is how to do this in the simplest manner (i.e., both time and expense wise)? My current idea is sketched below. The walls are approximately 19' and 18'. Total weight would be around 1100-1200 pounds since exterior sheathing would remain to prevent sagging. My thought is to use my 3-ton wheeled car jack and lift as close to the CG as possible (the up arrow in the sketch). Thus, I'd bolt some ledger boards to the walls (studs are 30-32" o.c. - I will be adding more!) and then bolt a braced 2x10 across the diagonal (should be 13-14') where it would connect just inside the midpoint of each wall since if anything I want the corner to lift before the ends. I'd have a person at each wall end to do the fine balancing as needed. Then basically walk the jack back a couple feet and set the wall down on some concrete blocks. That would be on the neighbor's property but I'll get approval from him. Once set firmly on blocks a while, remove the braced 2x10 so you could walk around the slab to install forms and do the pour easier. The brace shown on the top would remain from start to finish to help retain the right angle.
Am I forgetting anything?
garage wall sketch
EDIT: added picture of current sill plate.
sill plate
EDIT 2: Good news. Inspector has approved me just moving them to wherever I wanted temporarily so this will be pretty easy now. I'll remove the sheathing and separate the walls so my son and I can just carry them. :)
  • What alternatives have you considered? Personally, I'd try to avoid this much work. For instance, you could leave the walls, pour higher up to them, then with modest temporary bracing, pick away at discrete sections of the old wall and pour new foundation underneath. (Use lots of rebar to tie everything together.) Alternately, you could remove the sheathing and apply new later, which would bring the weight/hassle way down. Or get a crane. (Only slightly joking... we pulled an entire roofed porch off a house once so we wouldn't lose the grandfathered design.) May 3, 2019 at 13:04
  • How much interference with the house or other structures on the property would occur if you demolished the garage and built another which complied with the setbacks? May 3, 2019 at 13:13
    @AloysiusDefenestrate Pouring up to them, picking away and pouring a new foundation sounds like more work to me. :) I'd really prefer a single pour as well, which will indeed have a rebar grid in it.
    – topshot
    May 3, 2019 at 13:26
  • @JimStewart It would decimate what yard we do have. Both wife and youngest son are strongly opposed to a fully new garage even though that would be best construction-wise.
    – topshot
    May 3, 2019 at 13:27
There are a number of good ways to do this. Here's the first to come to mind if you're hoping to keep the wall upright. No jacks involved. In my experience, they're more trouble than they're worth when things are being moved laterally.
I would separate the walls, if that's not difficult. A "cats paw" nail removal tool and a few minutes would probably do the job. You could cut the nails, but you'll have scarring on the lumber, and sometimes that's more difficult than it sounds. This procedure should work well either way, though.
  1. Place a series of 8-10' levers with fulcrums along the wall, perpendicular to it. 2x6 laid over would probably work well. The near end of the lever should be just below slab level. The lever height at the fulcrum should be roughly level with the new slab height. The fulcrum should be near the temporary resting position, 2-3' from the slab. There should be clearance under the far end of the levers to at or below grade near the slab.
  2. With plenty of helpers, pry the wall off the slab onto the levers. Two people should have the sole duty of balancing the wall, which, if kept vertical, should be manageable. The others should monitor the levers and help pry. Flatbars driven under the wall and then lifted should make this step easy.
  3. Once the wall is completely off the slab, helpers should stand on the levers to lift the wall to the new height. This should be easy for average adults if there are enough levers (three or four per wall). The far ends of the levers should be a few inches below the height at the fulcrums, so that there's a slight rise to the new slab location.
  4. Now place blocking under the near ends of the levers, next to the slab. Leave room for concrete forms, etc.
  5. Shift the wall into its temporary position and brace well to heavy stakes in the ground. I'd use three if the wind is expected to remain calm, more if not.
When time comes to replace the walls, the levers should be at a suitable height. Just slide the walls into position.
Of course, you could always just lay the walls over and drag them out of the way. If you have enough help this is feasible. Four to six healthy adults could handle the walls individually.
Also, consider leaving the original sill plates attached and just add new, treated 2x6 underneath, flush with the sheathing on the outside. If they're solid, don't waste the considerable effort to change them, or just change the bad portions.
9
    I had thought of separating the walls, but am trying to comply as close as I can with what the inspector specifically said I could do, which was "lift" rather than move the walls. For your method, I would definitely have to move them far from the slab because I don't have the space to sufficiently brace them just off the slab as it's too close to neighbor's garage and alley. I'd also thought about just adding a new sill plate if the original really is solid. It's badly weathered but appears to be solid. Inspector was surprised how solid everything appeared.
    – topshot
    May 3, 2019 at 13:37
  • If you leave them attached there's very little bracing required. One at each end would do.
    May 3, 2019 at 13:40
  • I agree if I leave them attached I'd only brace the ends some, but don't think it would be easy to lever them off the slab as a unit. FYI, I edited OP to include pic of the sill.
    – topshot
    May 3, 2019 at 13:52
  • Why not? I've moved many walls. With the right tool they go surprisingly willingly.
    May 3, 2019 at 13:56
    That's fortunate. The entire situation is way beyond sensible anyway. Either you're rebuilding the structure or you're not. Clearly you are, and the rules have been circumvented. They might as well make it easy on you if they're not enforcing them. Good luck.
    May 3, 2019 at 15:03
