https://www.youtube.com/watch?v=9sI47qvVNiA
Actually works fine after this little blip.
According to bosch telephone support its a malfunctioning door sensor, but I'm not convinced as they originally said its because the door is open (which it isn't as follow-up movie shows same error with door closed).
I'm trying to avoid unstacking the dryer from above it.
  • If the door sensor is not working, it effectively reports the door open whether the door is open or shut - so they could well be correct... – Solar Mike May 3 '19 at 4:37
  • @SolarMike isn't there a specific error for that ? – NimChimpsky May 3 '19 at 4:38
  • There may be a specific error for an open circuit fault compared to short circuit - or vv... – Solar Mike May 3 '19 at 4:40
  • @SolarMike thanks – NimChimpsky May 3 '19 at 4:41
Never found a solution, but bosch did replace my machine with a new one.
| improve this answer | |
