we have an issue were our downlights have a dim glow when switched off.
electrician has been back to replace downlights but no success. glow doesnt happen every night, often a big gap in between glowing. tested the wiring and shows anywhere up to 3 volts through the active wire when switched off.
is it normal to have up to 3 volts running through the active wire? and is this enough to cause an LED downlight to glow.
cheers
