I recently changed my sons' bedroom light switch with Lutron smart dimmer. The house is fairly new and has not been remodeled. I have changed out about 3 other light switches without issue. This particular switch had an addition wire connected. I thought that maybe it was traveler so just didn't reconnect it when installing the smart switch. Turned on the power and the switch works well however, the receptacles (only in this room though the breaker runs 3 rooms) no longer work! What could this wire be? Thank you in advanced for your help.
    Can you post photos of the inside of the switch box please? – ThreePhaseEel May 2 '19 at 23:07
  • I will try to add pictures tomorrow. Thank you again. – Todd Phillips May 2 '19 at 23:36
  • "An addtional wire connected" But where and how was it connected? – Ecnerwal May 3 '19 at 14:40
Without KNOWING how it was connected (which it's always good to document before you tear stuff apart, but too late for that) I'm going to GUESS that the outlets were getting their power by being joined to the unswitched hot feed to the switch.
|improve this answer|||||
It happens all the time where a device is used for a splice, and the splice is unrelated to the device. So it seems inexplicable.
Let me pause and say the word "outlet" does not mean only receptacles, but any point-of-use including a light/switch combo.
As you certainly do know, there isn't a home run back to the panel for every outlet. Most outlets also have power being chained forward to the next outlet. Receptacles have extra screws just for this purpose (actually for dual purpose, but this is one of them).
In a switch, you have neutral coming from supply and carried onward both to the lamp and to the next outlet. An old style switch doesn't need neutral, so this 3-wire splice happens in the back of the box at a wire nut.
In a switch, you have always-hot coming from supply and carried onward both to the switch and to the next outlet. That's 2 wires + the switch. You can do that with a pigtail from the switch combining with the 2 wires (making 3 wires, almost exactly like above). However some installers just put the other 2 wires on the switch itself, using the switch as an ad-hoc splice also.
I recommend converting all such setups to the pigtail arrangement. First, it's easier to understand. Second, most smart switches have pigtails, so you'll have to do it anyway. And third, switches aren't intended to be splice points, but they have both screw and backstab. This splice trick typically uses the backstab, and backstabs cause nothing but problems - mostly open connections (and they're extra hard to find when they're at a switch), but also arcing, meltdown and fires.
  • I tried to add pictures but too big. I believe that Harper might be correct if I am understanding, I'm an engineer and know nothing about electrical wiring. Thought this would be an easy upgrade. I kept the original switch. It has the pos. and neg going into the back of the switch then an additional wire connected to the copper screw on the side. I am assuming that I need to tie two wires going into the existing and then tie that int the switch? Thank you guys for your help with this! – Todd Phillips May 3 '19 at 21:34
