I want to connect one outdoor stove and one grill to the gas line in my backyard . Should I put the Y connector before or after the gas regulator?
  • Usually connections are made after the regulator (you turn the gas off install the part and pressure test) if you don't pressure test at least get some leak test solution and check all the threaded joints prior to where you add the Y and after that point. – Ed Beal May 2 at 22:06
