I made a mistake and ended up with a very light coat of cured silicone spread in the ceiling. So looking at an angle, this ceiling area is shining.
I can't just scrap it off because it very thin and feels like stuck in the porous painted ceiling.
What would be the best way to fix this:
- painting over it is an option? maybe not, the new paint might not adhere to silicone.
- using a sandpaper to try to scrap?
- using vinegar (I heard it helps loose the cured silicone).
- using alcohol?
It's a small area so ideally I don't want to buy a whole bottle of solvent. However if it's the only solution I'd do it, I just don't know which solvent to use. Will it be necessary to repaint later?
Thanks!
