So I just finished my first tile job and grouted it. I got most of the grout off with the float then smoothed the joints with a sponge while getting some grout off. What I can't seem to find a clear answer on is when to wash off this grout Haze. I've read as little as 3 hours to as long as 3 days. Most of the how to is pretty similar, thinking I'm going to try vinegar and warm water sponge with 2 buckets, but how much longer do I wait? It's been 24 hours right now.
The longer you wait when trying to remove the grout the harder it gets, in your picture that is more than a haze, it should have been sponged more, but it's ok, you still need to remove the access by hard scrubbing with and plastic scraper, sponge with a corse side and water, if it does not have a high gloss look you can use a steel wool.
I just did this in my new laundry room. I compared using the sponge off method vs a microfiber towel, folded in quarters. No comparison. If you use your fingers to spread and keep the towel flat, it is amazing how much cleaner it gets the tile that a sponge. It is one of the best DIY tips I have ever discovered. I don't see why any professional would still use a sponge. The grout turned out perfect and there was so little haze left that I probably could have just let it be, but I did a post wash of vinegar and water to safe the next day.
Was this done while the grout was wet, like as your were floating it in? Or later after it dried. I actually did the same thing this morning with Microfiber, it did work great.– BigLakeMay 2, 2019 at 15:43
I used the towel for both the initial grouting and then the clean up hours later. If you were able to get it to work well after a full dry, it must be a combination of the tiny fibers (cleaning power) and the acidic vinegar. Post fix photos would be nice. Washing your hands with vinegar after using thinset is a must as well.– Evil ElfMay 2, 2019 at 19:07
Many years back we were tiling an area in a new shopping mall and a death in the family we let the haze set for ~5 days, we tried normal scrubbing but it was solid. We ended up using a weak muratic acid solution on the tiles just getting them slightly damp letting sit for a few minutes then wiping and rinsing with water it turned out great and this was a large area +500 1' tiles and you could not tell the difference from the previous section or the later ones when the job was done. Since then I have used. A dilute muratic acid solution ~5-10% by volume to water, it makes the cleanup much easier.
