I have a 220v circuit with two hot conductors. The connection has 4 terminals, L1 L1 L2 L2. The cable going in has a neutral conductor.
Can I hook the first of the L1 and L2 to the neutral conductor? What are the implications of sharing the same return path?
  • That depends on the equipment, and also your locality. We can't say definitely that it can, or cannot, be done, without a lot of information about your particular equipment. The locality (and wiring service type) also affects the question of whether the neutral can be shared. Apr 29, 2019 at 21:11
  • Where in the world are you? From some of your previous posts it looks like you're in the US, but this sauna heater looks like it's only sold in Europe? What country you're in will absolutely make a difference as to what is the correct way to wire it.
    – Nate S.
    May 30, 2019 at 16:40
  • You are correct on both counts. I contacted the manufacturer and he says to bridge the two L1s and the two L2s, respectively. May 31, 2019 at 0:48
