I have this stone floor in my new kitchen, and I'm going to need to cover it with something. I'm not sure what kind of stone it is.
The floor is really cold in the winter, so I don't want to leave it just stone. My question is can I cover it without creating problems with damp? I've been told the stone should be breathable and therefore not covered.
Stone flooring
    what's under the stone? if it's basement joists, then sure, if it's a slab on dirt, then probably not easily. you can try putting a plastic garbage bag on it under a rug for a day or two; any color change implies a moisture conduit, which contra-indicates schlepping on tile. – dandavis Apr 29 '19 at 20:13
you can cover with anything you want to, it all has to do with how much money you want to spend. the way it looks I would not lay any tile, that will be costly and it will still be cold. I would lay a free-floating that does not attach to the concrete at all, it just floats, that way if the concrete cracks are moves at all the flooring, will balance out and not crack are a break. that's why I was saying no tile, to much prep wood, floating all the concrete will cost a lot. and they make floating floors that look just like tile, wood, rock anything you want, and you can get it in waterproof, completely all of a rubber type material. with no kind of material that will swell up when it gets any moisture.
