It doesn't seem to want to lift up. I assume it is some sort of tongue and groove board because there are no nails or screws anywhere. When I press down on the lifted part with a lot of force it barely moves down. Not sure what to do here. enter image description here
    Take piece of scrap 2x4 and place it on top of the offending board, Take a heavy hammer and wack the 2x4 like you mean it. Report back. Alaska man is not responsible if you hit your thumb or split any of the boards.
    – Alaska Man
    Apr 29, 2019 at 18:59
  • the boards looks to be too long, shorten it. a dremel or oscillating saw would be the easiest way to do that w/o removal. could maybe even use a chisel or pocketknife or emery board and elbow grease...
    – dandavis
    Apr 29, 2019 at 20:35
  • @dandavis What makes you say that? When I stand directly over it there is a small gap between the two boards indicating it is not too long. This would also mean the lift would disappear in the winter but it does not.
    – ACD
    Apr 29, 2019 at 21:07
    from the pic, it (really really) looks to me like the high board is on top of the one closest to the camera.
    – dandavis
    Apr 29, 2019 at 21:11
Wood moves over time, no real way around that. The board could have been fitted so tightly originally, that over time it expanded just enough to force it up.
As already suggested, you could trying smacking it down with a piece of scrap wood and hammer. If that works, there are special screws you can use to screw the board down more permanently. The screw head is designed to break off to make as little of an appearance in the board as possible.
  • Well I smacked the absolute **** out of it and while it sticks up slightly less the issue persists. Can you link me to such screws? Or the name of them? I just screw them in near the problem area and hope it holds it down?
    – ACD
    Apr 30, 2019 at 12:31
    break away screws homedepot.com/p/… Apr 30, 2019 at 17:23
