I want to tap a hole in a surface that I think is steel.
According to the chart I need a 6.8mm drill bit but screwfix doesn't sell a 6.8mm hss drill bit. Can you use a 7mm instead?
For future reference sake, what if the chart said 3.3mm, can I use a 3mm drill bit?
