Is getting hot and I tried to power on my AC unit, it only blows warm air and no sound from unit outside, fan is not moving, no noise.
  • Checked indoor fuses were on and reset them
  • Checked outdoor fuse was on and reset it
  • Just changed the capacitor and turn AC on and nothing same situation
  • tested old and new capacitor with meter looks good
  • tested current in contactor and is fine to 240v
Capacitor
Contactor
When I push the middle part of contactor, AC starts should I replace the contactor?
  • Can you post a wiring diagram for your AC unit? – ThreePhaseEel Apr 28 at 23:06
  • Do you get 24VAC at the coil terminals of the contactor when the thermostat calls for cooling? – ThreePhaseEel Apr 29 at 0:04
  • I don't get 24v I connected my meter to blue and yellow and nothing :( – user260826 Apr 29 at 0:24
    Does jumpering R to Y at the thermostat base (with the thermostat removed) cause the A/C compressor to come on? – ThreePhaseEel Apr 29 at 1:57
  • imgur.com/gallery/c0WJPat this is the current setup – user260826 Apr 29 at 3:23
