I have the KDW60X16 dishwasher, and two days ago it started making a whirring noise. It will fill and drain fine - But will not spray/move water at all. The motor makes a 'humming/buzzing' noise when it starts, and continues for some time until I stop it.
I have removed the motor (YXW50-2E) and checked for any blocks etc.
I have found that the impeller is broken. I assume that this is no good and may be causing my problem?
I have also checked the resistance on the motor and the manual states it should be:
116.2 Ohms (Main Coil) 101.5 Ohms (Assistant) 41.4 Ohms (M1)
All +/- 7%.
I have the following readings:
158.4 Ohms (Main Coil) 117.2 Ohms (Assistant) 41.9 Ohms (M1)
Does the above readings point to a faulty motor?
I also have access to a capacitance meter, so I have taken the starter capacitor off and it checks out at 2.9uf (Rated at 3uf) - I was really hoping this was the issue as its best described from the manual as this but appears not?
Any help you can give me would be invaluable :)
Images attached of the user manual plus the broken impeller.
Impeller
Motor Ohms Spec
  • Why not replace the broken impeller and then test again.
    – Solar Mike
    Apr 27, 2019 at 7:42
You show a picture of yourself holding the smoking gun (if smoking guns can be wet): the wash pump impeller. Replace it, and you should be fine.
