My fridge is giving off a foul odour. Looks like the drip pan is growing mold in it. Looking for advice on how to remove the drip pan so I can clean it. It doesn’t appear to simply slide out from the bottom front of the fridge. It looks like it might come out from the bottom of the fridge but I would have to tip the fridge to attempt removing it this way.
Things I’m wondering are whether there is a better way to remove the pan for this make/model without tipping the fridge, and if I have to tip the fridge is there a specific side this make/model should be tipped on?
I also read that if you need to tip a fridge you should let it stand upright for at least as long as it was on its side before plugging it back in.
Any suggestions would be great! I’ve got a baby in the house and would like to get rid of this issue ASAP.
Make/Model: Frigidaire FFTR1821QS
