The following light was removed from my outside front porch because the bulb had burned out. Only problem is I didn't remove it and now I need to put the thing back up, but I'm not sure how the connection should be. Is this something I should even be doing at this point?
7I hate to state the obvious, but that's not how you change a light bulb.– BMitchCommented Aug 13, 2012 at 18:12
OP delivers!! I will not be trying to fix this on my own, I'll call a proper electrician in the area. Thanks for the advice all!– aherrickCommented Aug 21, 2012 at 0:29
It looks like you've ruined it. The stranded wires (such as the black one visible in the picture) are usually permanently attached to the lamp (Inside those cloth tubes). The solid wires are your household wiring. Normally you'd attach the stranded black to the solid black with a wire nut, and the same with the whites. Then attach the bare copper ground (or green) to the brass tab in the light. But it looks like someone just ripped it off and detached the stranded wires from the fixture.
Buy a new one, and if you are unsure of how to remove the old wires or correctly wire a new fixture, the safest thing to do is hire a qualified electrician.
Also, make sure your housemates read this: http://www.wikihow.com/Change-a-Light-Bulb
Agreed. Why replacing a light bulb required ripping the fixture from the wall I'm not sure!– StevenCommented Aug 13, 2012 at 18:23
1+1 for Chris Cudmores' clear answer and gentle urging to get skilled help. It sounds as if the original poster is not familiar with electrical systems and really shouldn't be doing it since it is a serious safety issue. This level of voltage can kill or start a fire.– bibCommented Aug 13, 2012 at 19:50
This almost belongs in "There, I fixed it..." I can see the ends of the stranded wires where they pulled off the socket. They're lucky it didn't blow a breaker or zap the person who pulled the fixture off. That poor little brass ring terminal for the ground wire just didn't stand a chance. Commented Aug 13, 2012 at 19:56
1Replacing the fixture is the safest and easiest solution. If for some reason the fixture is important, it's likely someone skilled in electrical work could repair it so that it operates safely and correctly. At least until someone tears it off the ceiling again.– bcworkzCommented Aug 13, 2012 at 23:03
Warning, dangerous advice, see comments
If the black and red cable is still long enough. Fiddle it through the hole and attach it directly to the bulb's socket.
2There is no red wire. This has to be grounded as well. There is no picture of the socket, but judging by the ground terminal that was ripped out, the leads were probably also ripped out of the socket and there is no safe way to fix it short of replacing the socket itself, at which point an entire new fixture probably makes sense.– gregmacCommented Aug 13, 2012 at 23:15
1This user does not have the skills to tackle this job at this time. Call in the pros. - @aherrick - DO NOT ATTEMPT TO DO THIS!– bibCommented Aug 14, 2012 at 0:06
1I agree with gregmac and blb, with the wires ripped from the socket, there's no safe way to reattach this. And without knowing aherrick's electrical experience, recommending he reconnect the wires could result in serious injury.– BMitchCommented Aug 14, 2012 at 1:07
When mechanical connections have been forceably destroyed like this, it's best to remove everything down to the solid copper house wiring and start from scratch. It will never have the integrity the original installation had. Commented Aug 14, 2012 at 2:20
BMitch, I want you to exactly explain how a serious injury could be caused. Commented Aug 14, 2012 at 12:00
