I just got done demoing a 20yo deck that had no footings or flashing. It was constructed of 2x8's on a 2x10 beam cantilevered. So, my design was to be all 2x10's with a flush beam because the deck is not high off the ground, there is a lot of erosion where the deck was and after I grade it I'm pretty sure there is no room for a beam under the deck framing.
So, anyway, this would call for a 2x10 ledger, the problem is that it would overlap the foundation wall by about 2 inches. I planned on using LedgerLoc screws to attach the ledger board and their min distance for bottom screw is 2 inches I think. But they do say that the ledger board should be no taller than the band joist.
The deck is only about 20 inches off the ground, does anyone see a problem with mounting the 2x10 ledger and proceeding as normal or should I shoot some concrete anchors in the overlapping portion or reengineer the whole design (not preferable)?
Thanks for any info.
