Getting ready to tile my first shower. Planning to start at the bottom and work up. Do I place the bullnose trim alongside the courses of tile as I go up? Or finish the big pieces then place all the bullnose pieces around the edge last?
While on the subject, is it ok to finish a few courses then come back the next day to finish, or should it all be done at once to avoid the thinset from drying out between courses?
You can indeed do a few courses per day.
Just make sure that there is no tile adhesive left on the wall in between tiling sessions or else it will harden and be a nuisance.
On the other hand, in my experience, the grouting should all be done in one go on a wall as otherwise it is a bit difficult to get it to join up again nicely.
    This is correct. It's perfectly acceptable to tile in stages as the mortar isn't part of the waterproofing strategy. Grout in one go if possible, or break at a corner. Color can vary between mixes even when working from the same package.
    Commented Apr 22, 2019 at 19:10
I think either method will work. I like installing the bullnose as I go up. That way, I can keep it all straight and plumb.
Starting and stopping runs the risk that the tile will not be embedded properly for a waterproof installation.
  • I don't follow your second statement. The mortar isn't part of a waterproofing strategy.
    Commented Apr 22, 2019 at 15:26
    @isherwood Sure it does. Here is a link from The Tile Council of North America on waterproof installation on various substrates. It’s very important to follow their guidelines or you could have a serious leak. It’s all good, but checkout Page 32: cusatraining.com/sitebuildercontent/sitebuilderfiles/…
    – Lee Sam
    Commented Apr 22, 2019 at 18:38
  • I still don't get it, Lee. I thought I understood that both the tile and its mortar were porous and that the waterproofing came from a membrane that goes between that and the backer. Commented May 30, 2019 at 19:26
