I am trying to install a new vanity and have run into some trouble trying to fit the plumbing needed under the sink because:
- The vanity is small
- The plumbing goes directly into the floor
- All the pipes are really tight together limiting the amount of space for PVC
- The PVC drain pipe leading into the floor is not straight up-and-down (it's crooked)
- The sink drain and drain pipe are located weirdly with respect to each other.
The following is my attempt at the plumbing, but I believe that the distance from the p-trap's union and the elbow is not up to code. Also, to get the old (crooked) drain pipe to line up with new piece of PVC, I cut the drain pipe at an angle which I assume is probably not the correct solution to the problem. Finally, the sink is now gurgling or gulping when water flow is strong and it wasn't before.
How can I improve my current design and could my current design have caused the gurgling/gulping?
Note: There is a vent that goes from the crawl-space below the bathroom to the outside. I am assuming that the sink is connecting to that. Also, I have not checked if it is clogged but it was working fine before I removed the old vanity so I am making the assumption that it is still working.
EDIT: Here's a picture of the setup before I removed the old vanity. Please note that I had already removed the sink so the sink drain is not there
