We've moved into a home with this brick patio that has sunken over time. The 6x6's have weathered and warped as well. I'd like to make use of the existing good bricks and essentially restore the same design.
A couple questions:
1) Any concerns using these bricks? they're different from some pavers I've seen in that they are flat, no bevelled edges. They are solid, which I think is most important.
2) Any suggestions for approach? Was thinking about getting my fall lines then tackling a section at a time (rather than pulling it all up at once).
Any insight is greatly appreciated!
  • Hello, and welcome to Home Improvement. This may be too broad a question for our format; let's see if you get good answers. – Daniel Griscom Apr 21 '19 at 17:55
