This fill valve is leaking, I have flushed it and it still leaks. Does it look okay or does the entire assembly need replacing?enter image description here
    Hello, and welcome to Home Improvement. This is a fill valve on a what? And, what make and model? – Daniel Griscom Apr 14 '19 at 20:25
Looks fine, but what about the diaphragm/washer assembly? That is the stuff that gets soft and worn over time; you most certainly should replace that if ever you open up the cap...
| improve this answer | |
