Should the wires being hooked up in a split bolt connector be running side by side, like in a wire nut connection, or running towards each other, in opposite directions. Or does it matter?
  • A picture or two? Not sure what you mean by a split bolt ... a split pin however... – Solar Mike Apr 14 '19 at 14:09
  • encrypted-tbn0.gstatic.com/… – Greg Apr 14 '19 at 14:16
  • encrypted-tbn0.gstatic.com/… – Greg Apr 14 '19 at 14:17
  • Sorry, trying to copy and paste a pic of the connector. Will try again – Greg Apr 14 '19 at 14:17
    Edit the question and click the insert-picture button. You can't put a picture in a comment (and edits are better when you are adding more information, too). – Kevin Reid Apr 14 '19 at 14:19
You can have wires entering from one side or both sides.
If I have 4 wires and I can arrange them neatly to come from both sides then I tend to do 2 and 2...
But if 4 on one side is neatest or convenient...
