my kitchen drainer basket is made of plastic without the usual lock nut. i could not remove it. this is the type of kitchen drain installed in my sinkside viewview as seen underneath. the yellow mark seem to be lock nut which is difficult to remove because it stucked
The entire lower plastic portion is the locknut.
Have a helper hold the strainer in place from above using a strainer wrench (it's a thing, sometimes called a spud wrench), or by jamming the handles of channellock pliers into it, while you get under there and unscrew the whole plastic body from the strainer (turn CCW if looking up at it from below).
