Basement finished few years ago, and electrician did all the wiring and gone. All lights have been working fine for several years. I recently had the need to change a light fixture, and noticed that the existing light fixture box, when opened, the fixture uses white cables on both the sides of the fixture (instead of one white and the other black). My new fixture has black and white wires. I am confused as to where should I connect the white and the black, the fact that there is no black wire used by the existing light fixture.
Apologies for the correction. My light fixture actually has one black wire and 2 separate white wires connected to two screws on the existing light fixture. My question is, how do I connect the 2 white wires to the new fixture's white wire (can I connect all three with a cap)?
