In the ceiling there is no light box and I can't insert nails or screws. I need to install a square LED light fixture, weighting 1.4 lbs, that is fed by the outlet. Maximum I can do is to damage the painting when I decide to remove this light fixture, because I can paint again later. The wire is very light in weight and is already in place using a double sided tape.
All that is left is to be able to "glue" this square LED fixture on the ceiling.
What ideas to you have to keep this square LED light fixture in place? I thought about these Command Strips, however I think they will fell in a couple of days, they are not meant to have force pushing horizontally, only downwards. They are not meant to be used in ceilings.
I also thought about these strong, permanent mounting strips (the red ones)?
I also thought about using a little of silicone, do you guys think it would work? Silicone has helped me in many ways before, not sure if it is effective in painted wall/ceiling.
The main question here is how to attach, in a secure way, this flat square LED light on the ceiling, without damaging the ceiling when installing or removing (damaging the paint is fine), probably using some kind of adhesive.
Any ideas are welcome!
Thank you!
