I'm planning to do something similar to this wiring diagram, but using only 1 thermostat : How to Wire 3 baseboard Heaters with 2 Thermostats
Since there'll be too many wires for the thermostat box, I'll use a jonction box between the thermostat and the baseboards. The wiring will look like this :
Breaker - Thermostat - Junction Box :
  • Baseboard 1 (3 ft) daisy chained in parallel with Baseboard 2 (2 ft)
  • Baseboard 3 (6 ft)
Please note I'll use a 3750W thermostat.
Just looking for a sanity check before wiring all, thanks for your help!
    Or you can use a larger junction box at the thermostat. For instance a 4-11/16" square box with a 1-gang mudring will give you enough room for like 6 cables. – Harper - Reinstate Monica Apr 10 '19 at 1:56
    1 - "daisy chained" and "parallel" are normally different. Do you mean 1 & 2 daisy chained, together parallel with 3? Or something else? A diagram would make it clear. 2 - How many W for each of the 3 baseboards? – manassehkatz-Moving 2 Codidact Apr 10 '19 at 2:05
  • I'm assuming my baseboards will consume about 250W per foot. Which gives 2ft=500 + 3ft=750 + 6ft=1500 for a total of 2750W – fred Apr 11 '19 at 11:55
  • You're right, my description is confusing... Baseboards 1 and 2 will be wired like this diagram : cadetheat.com/blog/multiple-heaters-just-one-thermostat – fred Apr 11 '19 at 11:58
