I have a Harbor Breeze ceiling fan with two light ports and a remote control. The lights are e12 (candelabra) base, but I need some brightness. I just bought some 12W LED bulbs (100w equivalent) and discovered something weird that I can work with, but I would like to know why it's happening. If I only have 1 bulb in, or if I have 2 LED, they don't work....but if I have 1 LED and one incandescent one, the LED works. I noticed that with just 1 LED, it seems to dimly pulse about every 2 seconds, but never comes on. I specifically bought dimmable bulbs....I'm curious why it works with an incandescent in there, but not otherwise
  • Just because the bulbs are dimmable, doesn't mean the dimmer in the fan is LED compatible. How old is the fan?
    – JPhi1618
    Apr 9, 2019 at 18:51
  • it's only about 5 years old or so, getting the model would be cumbersome because I'd hafta drop the fan to get at it
    – user99307
    Apr 10, 2019 at 19:18
LED bulbs work by using a power supply board (called a "driver) that converts your AC line to low voltage DC. The driver board takes very little power at first, then it excites the LED to make it glow and pulls a little more current. If your fixture uses solid state relays (SSRs) as the dimmer inside, those often require a minimum amount of current flow in order to function. If the LED driver current consumption is at or below that threshold, the SSR dimmer in the fixture fires, but will not stay on because there is not enough current flowing so it turns off again. When you add an incandescent bulb, you add enough current so that the SSR functions. This is what JPhi1618 meant when saying that the dimmer in the fan may not be compatible.
  • Good info - I didn't know why they don't work, but I did know that many old dimmers have an issue with modern bulbs.
    – JPhi1618
    Apr 9, 2019 at 20:27
  • That sounds entirely reasonable, I knew there was circuitry involved, but I didn't know why it was working in that manner. Thank you greatly for the insight.
    – user99307
    Apr 10, 2019 at 19:19
